When the smarty touch display dies, how do you get another one?
Well screen is dead just flashes the red led. Since now my truck is locked in its program and I no longer have any gauges or anyway to reprogram my truck. I need just the display.
  • Replies 4
  • Views 6k
  • The display side is where mine came loose as well.    Get a hold of @Smarty Support or www.smartyresource.com
it may not be the screen did you try to unplug it at the obd port for a minute or so then plug back in or mess with the usb port at gauges like wiggle it around the ports on these things are horrible i had one break off of the board on me
Smarty screen have a bad USB port in the Smarty side. Known to have the solder joint breaking. You'll need to box it up and send it to Smarty for repair. This is a known issues.
Smarty side as in the "brain'? Mine is a loose connector on the actual display. Anytime the screen locks I just unplug/replace/repeat.
Who do I contact? My understanding is you're saying the actual module has bad solder, not the display? If so it only figures I would be in the other boat....
Of course its when I'm in Norman, Ok and leaving tomorrow to head back to WA that I loose my gauges. Anyone near by that I can borrow a display to reprogram the truck. I have it turned up a bit and keep an eye on EGT's. :) Flying blind I would like to lower it a bit. I tried the not use so much pedal. Doesn't work for me.
Edited by 2500ctd
