Heater/HVAC Air only goes to Defrost Vent
- Replies 18
- Views 4.1k
dripley 5 posts
Mopar1973Man 4 posts
leety 4 posts
Manny 3 posts
Check for vacuum at the hose at the right out side fire wall.
Yes. It goes thruright where the AC linez pass thruu the fire wall. Mine broke there some years back. It is small 1/8" plastc lne. IIRC it has a fitting on lt. Be careful heat from the exhaust made mi
If you knocked the vacuum line off the pump yes, both would fail. The vacuum line to the hvac runs acroos the fire wall and thru on the passenger side. It is possible for that line to fail and the 4wd
Hi All,
I changed the resistors in my HVAC system and solved the fan speed issue. I decided to change the fan/motor as well and now there is no air coming out of the dash or floor vents only out of the defrost vents by the windshield.
Any ideas are welcome.
