If you have a 13-18 2500 or 14-18 2500 you are probably aware of this recall for the steering linkage.
The standard fix is to weld the adjustment nuts, something I won't let them do on my truck. I have been trying to get FCA to just replace the drag link with the updated one... to no avail.
I recently learned the part number and have ordered the part and will submit for reimbursement. It's cheap too, $132 to my door.
68338342AB or 68338342AD
So if any one else is in the same boat this is a better alternative to welding.
Posted (edited)
Thanks,
I wont let them do the weld fix either.
I put this info into an article.
Edited by Me78569
  • 3 weeks later...
It's installed and ready for a test drive... just waiting on a part to finish my Titan tank install.
Removal at the spindle was easy, but removal at the pitman arm was a PITA.
All in all it's a good looking piece.
Reimbursement form has been submitted to FCA and I'll update with their answer. If they deny it then I'm still happier spending $137 than a ridiculous weld fix.
