Quadzilla Issues
I’ve had a quadzilla on my truck since 2014, great results. But last night I went into my truck to start it, nothing no lights or anything both batteries dead, unplugged the adr then let the batteries charge overnight. Started truck, shut it off plugged my adr back in, crank no start unplugged the fuse tap and plugged it back in started but runs like crap. Unplug the ADR and runs perfectly fine. I have the iQuad and it will not come up on my WiFi connections.... when I shut off the key And pull it out my dash dummy lights stay on (Abs, CEL, low fuel, etc) I think this is why my batteries died but when I unplug the adr they all go off. Is my box fried? I pulled it out of the cover and there’s no signs of any burning or dark spots on the board. Any help would be greatly appreciated!
So update, I tried to reflash my unit and when I plug it into the computer it doesn't make any sounds or anything. the mini-b cable I bought says charge/sync on it so it should work, When I tried to install the driver 'devcon failed'
I'm the weirdest set up.
I'm running 18.04.4 Ubuntu Linux. Then have Virtual Box with Windows 7. Then I can run the Quadzilla flash updater. Typically on Linux side I will call out the...
lsusb
This displays all the connected USB devices. Then using this information I can enable on the virtualbox the right USB device Im going to use.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 058f:6364 Alcor Micro Corp. AU6477 Card Reader Controller
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 003: ID 045e:00cb Microsoft Corp. Basic Optical Mouse v2.0
Bus 003 Device 002: ID 045e:0752 Microsoft Corp. Wired Keyboard 400
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 04a9:26a3 Canon, Inc. MF4100 series
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Which gives you... Windows 7 running on top of Ubuntu 18.04.
