- Replies 4
- Views 2.2k
dripley 1 post
Haggar 1 post
Tractorman 1 post
Bojon 1 post
Popular Days
Dave, No not easily. I attached the wiring to the blend motor. (and put a snip here) You could check that the voltage varies on the yellow/orange relative to ground as you turn the knob f
The heater has been getting a bit slow changing from heat to ac the past month or so. So today, 55 and raining out it decides it is staying in the AC mode. I figure maybe the stepper is going dont know that it might internal to the box. I put the heater treater part in it some years back so I dont think thats the problem. Any good way check that motor to see if its bad without pulling it?
