- Replies 25
- Views 27.2k
Eviltwisted1 11 posts
dripley 6 posts
Brooks 4 posts
dieselautopower 1 post
eviltwisted1 My apologies, I had typed a reply that seemingly didn’t post. I did send a message to your Facebook account too. Nice work by the way, I used to help a friend of mine do that
try changing the "fuel system relay" with the "wiper relay"
Please help I'm at witts end. I just got 3/98 24valve and I'm trying to find out why it starts it right up, idles great and when you give it throttle in park for drive don't matter Motor doesn't go above 1500rpms . Got a code reader and it came up with what seems to be Dreaded P1689 code
Which far as.I can find is something NO ONE agrees on of the cause!!
I found this site from another diesel guy and I link I was given was here for 24valve 50\51 engine/obdii-error-codes94/P1689no-communication-between-ecm-and-vp44-r35/
I went through link and was able to get all way to #5 test which is checking ohms between #2terminal on FORM which is Supposed to be a "White Wire" and #13 on the ECM harness connector.
Well I don't have a White Wire anywhere in the rpms harnes. So I can't go beyond this test
At my shirts end and really don't want to have to pay mechanic $200 just to tell me what's wrong then whatever it will be on top of that.
Really need help
Also in reading and watching, remember something about it after fuel filter change that whatever is wrong will make it super hard to start. Getting fuel bled and fired up again. Now after changing fuel filter now seems that I'm having that issues also.( Battery started to run down so couldn't crank a lot to get fuel back up. After full day doors.open key switch on off alot .
Had to stop and charge up battery. I might get it started but still don't know why it not acting like the Raped Ape a 2nd Gem is Supposed to Be!!
Help please
Only has 113845 miles on it . Transfer pump relocated to in fuel tank.
Not sure what other help I can give at.moment. I need help though
Like most of us I ain't got a lot in life good wife great.daughter, he'll of a dog and not much $ especially just to have someone say it's this part that be $200 oh and if you want me to fix it, it will be X amount times 3 more plus cost of part
Y'all know the deal?
Thanks in advance for Any help
