- Replies 3
- Views 1.9k
Popular Days
bil, Across 85/86 the voltage should vary. During cranking it should be about 6v and running it should be 12v. You don't want that to die.... that is the signal for the fuel pump from
Ole girl has been sitting for a good while. waiting for glow plugs to warm up I didn't hear fuel pump run. The FASS 150 has been flawless on the 01 dually over the years. 12.95V from battery across 30 to 87 on the relay but only 8.5V across 85 to 86 with ignition on. Ive never been good at diagnostics, seemed logical. power and ground from original carter pump. That 2 pin connector leads into large factory harness that's run along the block should have 12V right?
