- Replies 8
- Views 3.6k
Threadzy 4 posts
dave110 3 posts
Manimalmother 1 post
Put the reman IP in. Dam she runs great! Before I could get 28-30 psi of boost. Now she hits 35-38. Everything overall is better.
By the looks of your mods you are pretty well educated and I don't mean to tell you things you already know. But this sounds like my truck a few years back. I was sure it was a loss of prime issue and
Can crossover tubes cause a slightly rough idle in park and occasional hard starts and not leak diesel into the engine? I’ve tightened the banjo bolt behind the head and the T fitting next to it. I park the truck nose down in the driveway no issues starting. Park it on level ground and every few startups it takes extra cranking for it to start. Injectors are fairly new. It didn’t start right after the injector install. Probably a couple thousand miles after. Thanks for any help.
