I have a 2001 Dodge 2500 5.9l that is stock other than a Predator mechanical fuel pump that I have recently put on. I have had the issue even before I've done any work to the truck of there being brief second of no power and then returning like nothing happened. I will be driving normal (Smooth accelerations) and every once in a while the truck will loose power and go back to normal in a matter of a second. I've always thought it was a problem with the stock lift pump on the side of the motor so i recently replaced it with a predator lift pump and haven't seen it run below 14psi. But even after I did so it still does this intermittent loss of power issue. It can vary from every other ride to weeks between cycles. I have no codes or lights on the dash and am starting to think it might be the VP disagreeing with me and wanting to quit. I have no tunes or anything going on with it and I tried resetting the APPS and nothing has changed it. Only other thing I could think of is air or suds making its way to the Injection pump every so often. Anyone have any thoughts?
Vinster,
It will drive you nuts. There are so many things it could be. ECM, VP, or it could be like you said, slugs of air, or random limp mode from the map....
My brother'
