Mounting a 70 gallon Freightliner tank in the bed.. Suggestions/Ideas?
So I picked up a 70 gallon Freightliner tank for good deal, to use as an aux tank in the truck.  I'm now looking into the mounting of said tank.   I got the truck's tank straps and mounts, but I don't see a viable option to use these just yet, as far as mounting goes..  The tank is 23D x 41L.
Anyone here done this before with a similar tank?   If so, pics?
Thank ya,
Rogan
  • Replies 5
  • Views 1.5k
  • YouTube Auxiliary fuel tank for pickup truck   part 1    Auxiliary fuel tank for pickup truck   part 2
  • I'm going to use the OEM J-hangers from the freightliner, but I have to make new saddle supports.   I guess I'll invert them, and where the brackets would normally be vertical on the FL, I'll make tha
YouTube
  • 5 weeks later...
11 hours ago, Royal Squire said:
Looks great. Do you have mounts figured out?
I'm going to use the OEM J-hangers from the freightliner, but I have to make new saddle supports.   I guess I'll invert them, and where the brackets would normally be vertical on the FL, I'll make that the bottom, against the bed-floor.
