28 lbs. boost
jag
Buddy has a 2004 - 2500 Cummins that will not make more than 28 lbs. boost. Tried plugging the wastegate (turbo is a 64 - 68 - 14) tried 2 different boost foolers, & a 20 lb. pressure test for boost leaks. Still won't go past 28. The only thing that I can find is the his MAF sensor is just plugged in & hanging there. There is no air box. Also there are no codes. We checked the MAP sensor & it is clean & not setting any codes. He says it made more boost even with it not installed before. Any ideas what else it might be? It also has a old BD fueling box with 3 settings & they don't even make a difference. Fuel mileage is way down to.
He is getting tired of being waxed by 4 cylinders!
I was just talking to him, & he mentioned that he had injectors put in 30,000 miles ago. I asked him what brand & if they were any bigger than stock. He said they were BD'S but didn't know what size. The shop that installed them is out of business, plus no part number on the invoice. So ends this hunt, but I have to agree with Me78569 being not enough fuel not knowing what they are.
Thank you
Edited by jag
error in mileage
