5 hours ago, Ravewolf said:
It's a mechanical gauge hooked directly to the fuel line, and I have a damper hooked in before the gauge hookup. Would it help if I moved it somewhere else? I just bought it for a temporary solution. I'm going to order a glowshift gauge kit here soon and redo it all.
Put a little needle valve instead of your dampener, then close it all the way and open it just a small crack just enough so the gauge rises slowly.
Thats the word I was looking for, needle valve. I need to adjust it so the gauge isnt trying to fling the needle off every second lol. I do have one though before the gauge connection. I just sometimes don't know if the fuel pump is priming right, so I open it a tad bit more just to make sure it didn't close by chance.
I also believe 90% of my problems are from the bad battery on the passenger side, and the wrong key in the pump. But I got my biden bucks today, and ordered a beans micro sump, and a power distribution block to clean up the mess I have on the terminals. Once it's here I'm going to do the WT ground mod, and other ground mods.
Thanks for all the help and info guys!
