Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
Having a new issue.. idling truck runs great very slight haze but nothing new.. take off down the road under low throttle it does great.. than between 20-50%ish throttle I begin to have white smoke pouring out.. under full throttle it’ll clear up to black.. I’m throwing no codes, turbo is rather new and have inspected behind filter and down pipe with no signs of oil.. injectors freshly pop tested, compression test recently has been done. Could injection pump be failing with no codes being thrown? Any other ideas?
