- Replies 7
- Views 1.4k
Mopar1973Man 4 posts
Doubletrouble 2 posts
jlwelding 1 post
Popular Days
I won't sell a FASS again. After all the head aches with them. Filters being struck because hanging too low. Pumps freezing up because of limited mounting locations. I watch a truck I install a FASS o
Owner just came and collected his truck and was pleased with the custom install of the AirDog 150. Tucked up out of the way and shouldn't have any problems. This is one of the few reasons
I ordered 1/2 inch lines, with draw straw outside the fuel basket. On his truck I installed the straw at the rear of the tank. Then added a big line kit to keep the stock filter housing. Then the JIC
I've got a forum member and local client here at the house with his Dodge Cummins having new +50 HP injectors, new AirDog 150 installed, and a big line kit. Now what I want to focus on here is my custom AirDog install and what it took to make it happen. On short bed trucks, the fuel tank is more forward toward the transfer case. There is not enough room for the AirDog to mount on the inside of the frame. Even on the outside of the frame is really limited using the supplied bracket and fittings. I chucked the whole idea out and started over, now thinking custom install. I had to call back to @dieselautopower and get the old school JIC fittings and have them as 90* elbows, not the straight quick connects. Now I took advantage of the outside of the frame but the rear of the rear cab mount. I'm using this as a guard from thrown debris. The frame is too wide to use the supplied sandwich bracket. So I used only the pump bracket and the plastic pedestal that is supplied. I drilled 4 holes and tapped the holes in the frame and bolted the pump to the frame of the truck. The 3 JIC elbows allow for the tight area and only one fuel line needed to be looped to prevent a kink.
The rear cab mount is forward from the two fittings on the left. This guards the filters against being struck by debris. The rear fitting pointing up is the return to fuel tank heading to the filler neck and the one pointing down was my supply to the engine. For the supply to the engine, I added a small loop to prevent kinking.
Here you see I completely did away with the sandwich bracket and just drilled and tapped into the frame. I couldn't use nuts because the fuel tank is completely in the way. The plastic pedestal worked out perfect too being allows for the brake cable not to rub the pump or filters.
