Painting Valve Cover
I think I’ll paint my valve cover while it’s off for the head studs install. I don’t really care about the looks too much, but if it’s easy enough I was thinking of using the same color of the truck which is patriot blue pearl. I can’t find that exact color in high temp. Will regular Dupli Color Exact Match spray paint work if I use a high temp primer and high temp clear coat? I’ll probably sand blast it to clean up the flaky oem paint.
Sounds like a solid plan.
I don't think the valve cover is much more than the standard 190*F to 210*F in temperature at the worst. It should hold up to the temperature being there is several other trucks with paint matched parts under the hood.
1 hour ago, Silverwolf2691 said:
Prismatic Powders has a powder coat that looks nearly identical to patriot blue pearl. Its called Misty Midnight.
Oh I could have way too much fun with this but knowing it will cost a pretty penny for this kind of powder coating.
