White smoke, low power when starting
- Replies 38
- Views 5.6k
Shimritz 14 posts
Silverwolf2691 8 posts
Mopar1973Man 7 posts
LorenS 7 posts
Weird and sporadic problems leads one to start thinking electrical. Have you done the W-T mod (see page 2 of Articles section)? Checked alternator A/C noise?
Your white smoke and power lose could be sticky VP timing piston that would be odd on a newer IP. Keep an eye out for 216 dtc code. Check for clogged fuel filter. Clean up battery terminals. And consi
@LorenS, even on a computer I make a new tab for the articles page to copy and paste from.. @Shimritz, if you put an "@" symbol before a screen/user name you can directly tag someone if y
Greetings. New subscriber, so maybe point me in the right direction please. Very intermittent throttle drop out out at 1800 RPM's (randomly every other month), check engine light: Code was MAPP sensor, TPS replaced 8 years ago with upgraded sensor and pigtail. Truck starts with no problems and runs fine, but then any push on accelerator produces clouds of white smoke and rough running sound. When beginning to drive there is low power and it doesn't run "right". After 5-10 minutes easy driving everything seems normal and it runs good with good boost (42#+ if I hammer on it).
I am taking it to the shop on Wed April 27 to have new MAPP sensor installed and pulling out my Bully Dog/Blue Chip FMS stack to install a Quadzilla to hopefully address some of my smoke and egt issues.
Any ideas or suggestions would be much appreciated.
I left out 75 HP Dynamite Diesel injectors on my sig
Thanks
