Oil leak after vp44 replacement
2 hours ago, DeepEastTexas2Gen said:
My cover was warped about 1/8”. I installed the Felpro gasket the first time but Dodd not use any sealant.
Ran about a week and blew out. That is when I checked for warping. Used the same gasket but used a sealant AND put the 2 1 1/4”X5” plates to add pressure on the lip of the cover.
Solved my oil leak.
Okay thanks I will look at getting one of the gaskets as well. Did you find a good place to purchase them
Some stuff I work on can be done 1000's of hours work with no speedy sleeve available or the machine needs to work "NOW"..... always the same with owners/operators it could have sat idle for weeks but as soon field service arrive to start a job it's needed yesterday
if no sleeve available or no time to wait to get one just instal the seal at a slightly different depth to where the old one was thus placing the seal lips both dust and oil in a slightly different place, most successful I did was an old Cat D8 dozer on a power station coal pile, the owners guys couldn't get the crank pulley nut undone so a huge pair of stilsons facing backwards over the crank damper and a 5ft breaker bar, once the damper is out of the way the crank was badly scored but luckily the timing cover was ally and had just a long bore for the seal with no counterbore to set the seal against, just measured with a DTI where the old one sat and set the new one different but the same all the way round.
On my timing cover I used black RTV
Don't forget to check the dowel pin when you take the timing cover off if you didn't last time
Okay sounds good will do. I did check the dowel pin and it looked okay it didn’t back out any. Any recommendations on what to do with the dowel pin
I just got a large penny washer trimmed it so it would fit.... it needs to be a bit egg shaped, there is a bolt right next to the dowel pin just remove the bolt and put the penny washer on it so it covers the dowel pin to stop it coming out, while you are in there check the torque on the timing case bolts, 3 or 4 of mine were loose I can't remember the torque on those though
