Good Source for Re-manufactured 47RE Automatic Transmission
My brother-in-law in Crescent City, CA has a 2002 4wd Cummins 2500 truck that has logged 175,000 miles.  The stock automatic transmission has failed l- no second gear.  I don't have any real details of the exact failure.  The truck is still stock - no tuner and original injectors.
The truck occasionally tows a very heavy 5th wheel (around 14,000 lbs), usually less than 200 miles round trip two or three times a year.  He has no near future plans of doing anything different.  Sometime down the road he may become a full-time RV-er and he will purchase a truck to match whatever he tows.
I was thinking of a quality rebuild with a lower stall speed converter that would work for his current situation.
Any vendor recommendations would be appreciated along with any helpful suggestions.
Thank you,
- John
Thank you @IBMobile, we may be moving forward with this re-builder.  I just talked to my brother-in-law about the Stage II transmission from Dynamic Transmission.  He has determined that he will likely be keeping the truck, so this transmission would be a good match for his needs.
- John
