Fuel hose anti spill valve needed
- Replies 10
- Views 2.7k
LD-Ordie 4 posts
Max Tune 3 posts
JAG1 1 post
Royal Squire 1 post
https://www.perko.com/catalog/fuel_system_components/313/special_application_inlet_check_valves_-_flapper_valve/ I always check the boating industry for unusual things.... I'll add this also..
@LD-OrdieThat Perko check valve is on Amazon
My flatbed doesn't have the anti spill either. I have to fill so slow that I cannot use any of the nozzle fill notches that holds the nozzle in the on position or they fill too fast and then shut off
Recently installed a flatbed on my 99 3500. Could not use the original filler tube with the anti spill valve, Now I'm taking a bath every time I fill my truck with fuel. Not sure I can remove the original one without breaking it. No luck finding one on the net or local parts store. Anyone got a source or an option?
