- Replies 12
- Views 1.3k
JAG1 5 posts
Tractorman 3 posts
Max Tune 2 posts
IBMobile 1 post
Popular Days
Mount the bike on front of truck.
My concern would not be the hitch rating. It would be the unweighting of the front axle. Your modified load may be 4 feet behind the hitch, but it is closer to 7 feet behind the rear axle. The re
I have a feeling that he has considered that option, but doesn't want the bike mounted there. - John
Want to know what you all think since I have a truck camper that overhangs out the back, plus folding steps putting it out even further Then the swing out bracket required another 8 inches of clearance to swing around the corner. So 48 inches is to the center of the fat tire rack. Bike weights 57 lbs w/o the battery and the swing bracket and rack weight around 100 lbs. So only 160 pounds but, it's out there 4 feet!
. Do I have a serious situation and is there a special brace I can get on there to rectify the issue? Thanks in advance.
