I could school you up in what I know for the 24V programming I do. Timing is a neat animal to work with. :burnout2:
Quick tidbit just remember more you retard easier to build boost. More you advance the more you burn the fuel in the cylinder but you have to be careful. I monitor my oil temp being that if your over advanced you will gain heat in the oil because you flood the cylinder jacket with heat with fire burning on the cylinder walls. Optimally you should be about -30°F cooler than coolant temperature. This will provide the best bang for the buck for daily drivers.
I had a new FelPro 9522PT with new head studs and it failed within a 1k miles, but I think it was too much timing on the Quadzilla tune that I was running at the time.
I swapped over to a Cometic MLX head gasket # COMC5855-067. I didn't have any more issues after that.
Wow, what were your timing numbers?
You can run quite a bit of timing as long as the boost is near zero. No more than 5 PSI for above about 22 to 23 degrees.
Again another example I can run 26 to 27 degrees of cruise timing at 2,000 RPM but I'm always below 5 PSI of boost. This is why I monitor my engine oil temperature because to advanced engine oil temperature will rise up past coolant because the amount of flame on the cylinder walls. Also watch engine load numbers it will rise because of negative torque.
