Posted (edited)
For all of you that use a Big Honkin' Air Filter like myself. While back I quit putting the air filter minder in the head of the filter, well I went a bit too long on this filter even though the restriction is minimal really didn't see any huge temp difference per se. Now changing to fresh BHAF supplied by @dieselautopower and got it installed. Very small changes in temperature did occur. Coolant is down about 3 degrees, engine oil temperature is down about 3 degrees as well. Now EGTs really didnt change a lot but cruise state seems a tad cooler hard telling. Now as for MPG just making the trip down for my chemo appt. I only used 1/8 of fuel for 125 mile trip.
I did go toe to toe with a sport car running the canyons. Kind of fun to have quicker spool and just a bit more fuel/air mix keeping heavy throttle usage a bit lower in EGTs even on level 5. :burnout2:
  • Like 3
