ATTENTION ALL!
Patient: the truck in my signature. I had high boost readings on my Quad (up to 50 psi at idle) and those numbers dropped about 10 psi with the install of a new DAP map sensor. I then removed the Quad unit and sent just module to DAP to be checked out. While I had the Quad being checked, I installed my old Edge EZ. The module didn't have any issues so they sent it back to me and I have not reinstalled it. With the EZ, I get an almost constant "high boost " error code even after replacing the map sensor a second time. I was able to keep the light off long enough to get a smog check done but I now want to sell the truck and I need to figure out this error code issue. Can anyone offer any suggestions on where to start trouble shooting this? Is the MAP sensor terminal end wiring replaceable, I have not checked to see if it is.
Thanks!
  • Replies 1
  • Views 184
  • Mopar1973Man
    Boost fooler damaged on the Quadzilla module?   Wiring issues to the Quadzilla module? Proper wiring used on the Quadzilla? (No hacking up the connector to fit a later series?)   S
Since the boost number is high on the Quadzilla I would have both the module and the wiring checked.
Did This Forum Post Help You?
