Bunch of code and the ABS brake light came on
250 - Injection pump??251 - Fuel Inj. Pump Mech. Failure Fuel Valve Feedback Circuit230 - Transfer Pump (Lift Pump) Circuit Out of Range500 - No Vehicle Speed Sensor Signal501 - Speed sensor1689 - No Communication Between ECM and Injection Pump Module1693 - Companion code1765 - Trans 12 Volt Supply Relay Ctrl Circuit (Mystery switch) As for the brake light I have it happen from spinning trhe tires and most times I press the pedal hard and it resets... Since there was no ABS light its not a speed sensor failure. The rest seem to be a rash of injection pump codes...:rolleyes:
Thanks mike for the list of what the codes mean. It would seem as if i might have a SOVP44 heading south. I don't have any driveability problems. It runs fine. Where would a guy go from here? 230 I have a f.a.s.s????? 1765 is a mystery switch. I wonder if the 1689 has to do with the random no HI idle problem? I got to see if i can find someone with a smarty to wipe out the codes and see what comes back.
