- Replies 23
- Views 8.1k
Terry C 6 posts
Mopar1973Man 5 posts
white01 5 posts
John T 3 posts
I used a flushing kit.. you know the kind where you put the T-fitting in the heater hose and then connect a garden hose.After running a bottle of radiator cleaner for a day, I drained and flushed as directed with heater on high.My question is this: while flushing, does the water really cycle through the entire system? I ask because it never really gets hot , and I'm assuming the thermostat never opens.So I'm gonna run straight water for a day, then drain again (maybe do that twice over a couple days)then add my distilled water/antifreeze.Anybody see any problem with this?Thanks, John
