axles and transfer cases
Prowelder you have the letters wrong
they are
NV 241 DLD= Dodge light duty
NV 241 DHD=Dodge heavy duty
Dodge W150 and W250 trucks (except Cummins Diesel models) from late 1987 to 1993 have the two speed, fixed rear output yoke, NP241, chain drive aluminum transfer case. All 1994-2002 Dodge 2500 and 3500, 4x4's are equipped with NV241 transfer cases and slip yoke type rear output shaft. Dodge 241's have a planetary low range ratio of 2.72:1. There were numerous design changes in the 241 during its production life making parts selection a bit tricky without the transfer case build tag. Starting in 1994, the stock 2500 transfer case was the NV241DLD (Dodge Light Duty). Optional on the 2500 and standard on the 3500 was the NV241DHD (Dodge Heavy Duty). 1999-2002 Ram 2500 and Ram 3500 4x4 trucks with the High-Output Cummins Diesel NV5600 6 speed transmission use the NV241DHD. 1994 to 2001 Ram 1500 models can have either a NP231, NP231HD, or NP241 transfer case depending upon the year, engine, and transmission combination.
The NP271 manual shift and NP273 electric shift, chain drive transfer cases are found in Ram 2500 and 3500 models effective for the 2003 model year. These transfer cases feature larger rear output shafts to handle the ever-increasing power of Dodge factory engines. The redesigned 2003 Ram 1500 debuted with a re-worked NV241D transfer case that is not interchangeable with prior models
they are
they are
great info ...so from what i gather as long as the two previous owners didnt change anything i should have the 241 dhd .....1998.5 3500 4x4 ...as soon as i can get under the truck with out needing a snorkle ( 6 inches of snow here in southern ohio )...I know not alot compared to where most of the members are but still.....i will check the transfer case to see that the tag says nv241hdh
Yeah I missed the 3500 part the first time through!!:lol:
