Anyone running an Edge Insight CTS?
AH64ID
I think I am going to move the SG to the DD and get an Edge Insight in the Dodge. It does so much more than the SG, and has several features I would like to have anyways (post-turbo pyro, turbo timer, and various pressure/temp sensors, backup camera). I'll probably start with just the post-turbo pyro and oil pressure. By using the CTS for oil pressure I can move my pre-turbo pyro from the A-pillar to the dash mount and have room for the CTS under the A-pillar. Down the road I would eventually like to monitor oil temp, diff temp, and trans temp. The OBDII gauges will be better than the SG since Edge actually has PID's for Dodge, so I will be able to monitor rail pressure with the Insight as well, and continue to monitor IAT's, Load, and Coolant temp as well. The insight also allows for 8 gauges on the screen vs the 4 on the SG, so I think it will be a good upgrade! But I haven't read much feedback on it. The feedback I have read is excellent, but its very minimal. So does anyone have any experiance with it?
I take it that this is just a monitor then???? There's no programming for HP and Torque increases??? When I ran the Edge J w/A, the monitor always performed flawlessly with whatever parameters I wanted monitored. I took it out after I got the Smarty because I also put in hard gauges and I didn't like the idea that even on "stock" Edge programming, the truck was still using the Edge pigtail injector loops while I had the Smarty downloaded. I liked the Juice...........good power, but ran Hot when you got on it.
  • 2 months later...
