Every towing forum needs one of these posts... right? :thumb1:
probably the heaviest I've ever been. I didn't scale, but those are V8 E250s
And finally what I really got the whole rig for. My Dakota is the rig in back.
What to do when the tow rig gets stuck
  • Replies 124
  • Views 29.2k
I usually get around 11 towing it seems. I don't go slow, as discussed elsewhere, but I don't rip it at 80mph either. weight on the trailer doesn't seem to matter. I get the same mpg with a pair of E250s as I do with a single Mustang if I'm running similar terrain and speeds. within 1 mpg at any rate. Even my empty trailer is enough to get me in my 'towing' mileage, it's about 4600# empty.
c 1986 My half ton (ex got it, minus towing equipment) GMC, 305, auto, originally 3.07 gears. Ex's brother changed the ring & pinnion as far as we could go with that center section... can't recall but 3.55 or so I think. It towed much better (though even with a oversized flex fan it built heat on the grades). Interestingly, the mpg improved with the gear change... upshifted sooner.
Moritz, steel stock trailer was later sold to someone who works with my brother. Heavier than a brick outhouse. Damn near bullet proof.
c 1989 My Scamper Camper, residence post divorce. My 79 Chevy C30, Camper Special, built 454, auto, 3.73... pass anything on the road but a gas station. 11 mpg loaded or empty. Enough power to haul that camper to 100 & beyond.
C30 & Moritz trailer loaded for our Rendezvous trip. Hand built wagon in the back of the truck. New body panels on the truck... post cab-off restoration.
Here is my little backhoe! She weighs in about 21k! Had to step back a few feet to get it all in one pic!post-10918-138698177508_thumb.jpg
That's what she said! LOL
BTW, can you bring that hoe up to my house, so I can fill in this swimming pool?
I don't have a suitable trailer. I hired a friend (owner / operator) with his cab over & his bosses low bed to have my JD410 (14,000# according to the book) moved to the house when I bought it.
That's a light load! What kind of trailer do you want?
I found out the hard way, never trust what the book says equipment weighs! The bucket that I normally run on my backhoe is a 39" wide bucket it weighs almost 1k itself! Add that to the machine plus the full fuel tank, hydraulic tank it adds up pretty dang quick!
I never thought about it. The front bucket has been enlarged & reinforced with plates welded on. The hoe bucket has been repaired & reinforced. No telling what weight that added (if it was ever right). Tires, the front ballast weight... a lot of things could add to the total. I'm retired & the machine seldom leaves our property. If I needed to, a local contractor would move it on his trailer.
  • 3 weeks later...
I like the homemade firewood hauler with the cop wheels. :thumb1: Got theose on my car trailer as well. How did he get that boat on top of the truck? I know it isnt but looks like it is just sitting on the topper. I gotta find some of my pics. Not anything cool, just lots of miles with the same trailers.
My '96 bringing my '01 home, last summer. I sure miss Ol' Blue. It was 10x the truck that the 24V is..
What size axles are on that trailer? My car hauler only has 3500lb axles, and my 01 weighs in around 6500. Looking to upgrade the axle on my hauler to 5200lbers.
My 01 QCSB weighed in at 7760 at the dump, empty...:shrug:I think they're 5200s on the trailer.
Wow, those are light. I'm 8500 with me, full tank, toolbox and spare tires. 13sp and duals/19.5s add up! I'll be close to 9k when I get four wheel drive back. Someday I'll get the dead spare off the broken winch under the truck and put the trailer spare on the trailer, thatll help curb weight. Maybe move the 100+ of straps and chains to the trailer someday too...
I finally downloaded some more pictures! Here are some storm shelters that I hauled recently! Each half of the storm shelter weighs approximately 5500 lbs!
I should have taken photos this past weekend! I had my dads 2005 2500 and 35' goose neck trailer loaded to 22,400 lb with 9,600 lb of hay.
Well, I thought about this and verified.. 3500s :nono:
Here's my overloaded 24' "business in a box" Trailer grosses out just under 9100 lbs. Yeah, a tad over rate.:duh: I'm looking at picking up a new CAR-MATE 34' gooseneck for $11,5k..
1500sqft of sod. 2500 lb per skid.
The results of the above:
what it was before the sod:
Buddy of mine needed his house trailer moved! It was a 12'x60'! So I hitched up to her, hooked safety chains, rain an extension cord for my s,t,t lights, and spent $50 for permits in Arkansas and Mississippi! And off we went! It was a really easy pull for ole betsy! The trailer made it to its new resting spot and my good friend is extremely happy!
One of my favorites although it wasn't pulling a trailer but I did have a payload :D (The old dude leaning on the truck is NOT me btw)
Will you be my friend?
Cute little local trip tonight. I'm not sure the pair of Mazda2s outweigh the trailer! Sure doesn't feel like it.
Yes, my pile is FILTHY. It hides a little bit of the rust :-D
