I am thinking that a Low FP Warning would be a good idea... Who offers one? My thought is to T the switch in when installing the new FP gauge. Your experiences?
  • Replies 13
  • Views 6.7k
Most all low fuel pressure lights like even the Cummins one doesn't trip till 3.5 PSI... Even most of the aftermarket don't trip till 5 PSI which is still too low... :duh:
If your going to build a low pressure setup find a Hobbs Switch that is adjust able and set it for 8-9 PSI for trip...
Snagged this pic from another site but the principal is the same just use a adjustable Hobbs switch and adjust it for your low point 8-9 PSI and your good.
I'm having trouble finding these. Where's a good source?
edit
I just found these:
-NAPA/Balkamp Adjustable Pressure Switch (NAPA) P/N: 701-1577 high pressure
-NAPA/Balkamp Adjustable Pressure Switch (NAPA) P/N: 701-1575 low pressure
31.99 or some such
I have bid on a switch on ebay. (Please don't bid against me!) Do you all use a light or buzzer for Low Fuel Pressure? As much as I don't like it, sometimes the wifee drives my truck. ("What's mine is mine & what's yours is mine also!")
I would put the money towards a gauge, a low psi switch doesn't really tell you much.
I am installing a gauge(s)... planning to T the warning at the same time.
I guess if I read your post I would have known that.. Personally I don't think its worth the added cost.
I'm hoping to do the Low FP Warning for minimal cost at the same time as the gauges. I would not be bother for just me... However, I don't really know how well wife minds things on those ocassions when I can't get out of her using the truck.
Other than not having to watch the gauge what do you really plan to gain from a light? I am sure there are 10 psi switches out there, and thats what I would get.
That is all: a light / buzzer. If I can do it for few bucks... Why not?
  • 3 weeks later...
I put in a BD low pressure warning light (like this one http://www.xtremediesel.com/bd-powerlowfuelpressurealarmlightkitred.aspx ) when I installed my Air Dog 100, and I wish I had spent the extra money on a fuel pressure guage. I've had several issues, that I might not have had if I had a Fuel pressure guage. The AirDog is kind of exposed outside of the driver's side frame rail under the truck, and when I drive in the snow or slush, sometimes the ice buildup on the connection will conduct enough electricity to ground out the hot wire and trip the light. Also, the light only comes on when it's too late to do anything about it. I had my fuel filters gell up at -20 F, and I wasn't able to see the pressure dropping like you would see on a guage. All I knew was it had too little pressure to feed my VP44. My next purchase will be a fuel pressure guage and a three guage "A Pillar pod" (and relocate my boost and EGT guages). My three cents is to go with a guage.:2cents:
I'll say it nice way of getting your attention on the gauge when there is a bright LED winking in your face... :lmao2:
FWIW, Mine's not very bright. I mounted it on the top of my steering column. It stands out bright and obvious at night, but in the day it won't catch your eye.
