A/C Leak found!
Well I got to admit I learned something and feel like a dumb arse...:doh: Ok years ago I stuck a piece of hardware mesh in front of the coolers to protect them from bug, stones, etc. What happened is the wind was flexing the screen and rubbing the A/C condenser. If we dig in the archives I'll admit I JB welded the rub marks thinking to protect the line from future damage. Well the damage was done. :banghead: I took the truck to Lewiston, ID to let a tech track down the leak for me. Found out R134A freon mocule is so small it passes through the JB weld epoxy and the tech found the green dye leeching through the JB weld. Sad part is the condenser and the high side pipe are both damaged. So After getting bids around Lewsiton, ID I found out its much cheaper to get the parts through Rockauto.com ($24 for the high side pipe) than a part store ($48 for the high side pipe) or the dealer. ($130 for the high side pipe) :rolleyes: So I got to order a few more parts and get busy again...
