Oil leak (another thread)
i know mine is still there after dodge replaced my oe lift pump with the intank pump and there is a reson for them leaving it there. i just dont remember why. i think one or both othe bolts penetrate the oil jackets in the block. i dont know that for sure, but i believe i have read that some where.:shrug:
Hey HEavy There's a different gasket there ?? :shrug: hmm .... so hard to see back there .....I can see most of the oil is right at the back of the block - but yeah the OEM lift pump is quite close to the oil also Whats that gasket for ? And why does it leak oil if its related to lift pump ? Might have to get the starter motor off after all ...... can't think of a better way to get a look at it without taking everything off the top
Sorry John for the late response. I had the same leak on my truck when I removed the lift pump bracket to clean up that side of the block and then a couple months later the leak appeard!:doh: After taking it to a good friend/mechanic he told me that there is still a boss behind there for what was used for the 12v lift pumps. I guess Cummins never removed the boss for the 24v block.:shrug: So the gasket is behind the lift pump bracket and there is another plate that the wiring harness runs thru and clamps too behind all this. :smart: I hope this helps John. Good luck.:thumb1:
  • 8 months later...
I am curious if you ever got this one fised also. I have got a leak at the rear of the engine myself. It appears to be wet along the bottom of the back third of the tappet cover. I can see it along the bottom edge, but cant see much else without taking some stuff. what di your end up being?
No havent done it - as pretty sure its my tappet - and if I do pull it - going to go billet and be done. $200 - blah
I think I am going to use the oe with anew gasket.:broke: Probably will wait until I get her home. I am living in the rv park. You knowhow that goes. I got up a day break Sunday and change the fluid in my front diff. It was leaking on ther new concrete.
