When pulling heavy load (18k) I put it in tow/haul but it seems to still have all gears, I thought it would stay out of overdrive. Is it pulling in overdrive?
  • Replies 6
Mine does as long as the button was pushed before I started. If I hit the button mid cruise it downshifts and stays a gear lower. I have found it pulls much better in tow/haul when I am towing.
With a DRB the dealer can make it OD off, but you don't get to go back and forth if I recall correctly. I don't know if there are mystery switches you can install to give OD lockout??
  • Current Donation Goals
    • Raised $20
