I got my fuel issues fixed with my new AD100 and took off for the oil field and the transmission will not start out in 1st gear unless I put it low manually. :wtf:I cant take the chance to run it till I find out the problem, Anyone else experience this!!:banghead::banghead::banghead::cry::cry::cry::mad::mad::mad::mad::soap:
  • Replies 3
Popular Days
So what gear is it starting in ??? Limp mode ? Have you scanned for codes and tried the key trick for codes ?? I would check the fuses , disconnect battery and reset the APPS (30 mins) ........ and then play around with the TPS :)
Thanks to some help from a few members on here and CUMMINS FORUM I changed GPS solenoid and Transducer and it shifted normal on a 20 mile trip stop and go it started out in 1st every time:hyper::hyper::hyper::hyper:
  • Current Donation Goals
    • Raised $20
