- Replies 14
- Views 4.1k
AH64ID 5 posts
haynsling 4 posts
Mopar1973Man 3 posts
MnTom 1 post
2003 CR bone stock with a Frybrid WVO system installed but deactivated. Been running from only the diesel system for 4 months (bought the truck in Dec 10) no problems except for a slight miss. About 3 months ago the mis got real bad and sounded like the valve train was trying to escape. Took it to a freaind who ran his OBD scanner and told me # 1 & 5 injectors not firing. Changed all six injectors! No change?? Took it back and now he said the injection pump no good. Changed IP and Lift pump! No change?? Also after the pumps change putting out 0304 code. looked into wiring issues and couldnt find anything. Was told to check wires on the back of the A/C compressor and the alternator. Looks goos to me. Another friend suggested i put seafoam into fuel tank... did that. Truck sat at shop for 2 months and no change. Drove the truck for about 100 miles and the symptoms got worse. Took her home and when I tried to start it the next day dead batteries. 2 new interstate 850s and she cranks perfectly but wont start. Im f%@!n stuck guys any suggestions??
