fuel filtration calling AH64ID
after my fuel life thread kinda turned into a fuel filter thread, i thought i would just ask what is best.my set up;AD II 165 with AD filters, run to the stock fuel canister, vulcan bif line kit to the vp.i am currently running the stock filters on the AD and the filter in the stock fuel canister is what ever i bought last. it seems the filter in the stock fuel canister no matter where you buy it is the same. in other words i do not have a clue as how good it is. My AD has a WS100 and a ff100-2. i need to order some replacements. thru all the discussions i am not sure which way to go. AH you are the man on filters which ones should i be using. As a father who has one son and one son in law in the military, your service is greatly appreciated and your opinions are respected. your humble tax payer, Dripley to some
  • Replies 10
  • Views 2.9k
You're welcome, and thank you!I would run a Baldwin BF1275 f/w sep and a Donaldson P551315 on the AD, and a Baldwin PF7977 in the OE canister.
And I thank you as well for your service to our Country. Secondly, for continuing your service to others here in these forums. In my short time on here your advice has been valuable and reliable. Thanks.My son served in Iraq as well. Came home alive, Thank God.
You're welcome, and thank you! I would run a Baldwin BF1275 f/w sep and a Donaldson P551315 on the AD, and a Baldwin PF7977 in the OE canister.
thanks
SaWeet! AH64ID, your the man! But you probably know that!:) Dave
AH64ID, as stated earlier, I am going to install a new AD 100 this coming week. (it arrives Monday) In your opinion should I leave the filters that it comes with in it, or, are they of such poor quality that I would be well advised to pull them and install the Donaldson and Balwin?Second, Does the AD100 use the same filters as you recommended above to Dripley for his AD II 165? I believe they were the Baldwin BF1275 and Donaldson P551315.
I would change the f/w sep out, but the final fuel filter is fine. Its 5um absolute, vs the 3um for the Donaldson.
who is a good source for these filters?
I started calling my local distributors, listed on their websites, and found that I could get them locally for the same price as online. If you have no local distributors I have heard good things about www.apartsdepot.com
