Fuel Pressure problem, need help
- Replies 35
- Views 6.1k
RJC2 16 posts
dripley 14 posts
JAG1 3 posts
Mopar1973Man 1 post
Alright guys, I replaced my lift pump a couple of weeks ago with an Air Dog 100, installed the draw straw V, and big line kit. Everything was going well and I had 16.5 PSI at idle, 13.5 at wide open throttle, consistantly. This evening I was running just below a 1/4 tank and stopped and filled up. Started the truck and had 16.5 psi. I drove 24 miles home and watched the fuel pressure drop slowly to 5 psi by the time I got home. The truck is running fine, and I see no fuel leaks under the truck. My first thought is "bad fuel" and the filters are clogging. I have an extra set of filters for the Air Dog and the factory filter which I plumbed in with the Air Dog. My first inclination is to change the filters and see if the pressure comes back up, but I thought I would pick your brains and wait till morning before doing anything.As a side bar. While filling up at the service station (which isn't the one I normally use) the pump was running very slow, so I got in the truck while filling up (28 gallons). An employee was standing in front of the store smoking a cigarette and walked over to me and asked if the pump was running slow and I said yes it was. He pointed out that all of the gas pumps had plastic bags over the nozzles because "they sell so much fuel that they ran out and diesel was all that was left.I don't know how much diesel was left in their tanks but I have to wonder if I got the bottom of the barrel!Any thoughts or suggestions are much appreciated.
