ATTENTION ALL!
while i was driving along today my battery voltage gauge suddenly peaked up to the maxwhen i pulled over as soon as i started getting slower it dropped back down to normal and the rest of the way home it stayed normalwould a short somewhere have caused this?i had been using cruise control but im not sure if i had it engaged when it happenedmaybe it was the cruise control and once i slowed down causing it to disengage it returned to normal?:shrug:
  • Replies 8
  • Views 2.3k
Check the green wire between the alternator and the PCM for shorts to ground. If this wire shorts to ground the alternator will run wild at max voltage...post-2-138698181472_thumb.jpg
Ok after trying an external voltage regulator with no luck I had the alternator tested and it was doing some screwy things New alternator in and I've got only 12v reading in the gauge and after a few minutes it drops to Zero with no effect on brightness of lights --- I am here: http://maps.google.com/maps?ll=42.674987,-84.075746
explain this again? what is the voltage reading on the battery terminals when idling? are you sure the grid heater solenoids are not stuck closed? i dealt with a similar issue of zero on the batt gauge...
that new alternator is hosed. you should have around ~14vDC on the battery terminals with grid heaters off. it will drop to ~12vDC when the grid heater kicks in. I have checked this with a meter on the terminals with these results and grid heater cycling.
I can get the fuse tomorrow how safe woul I be to run a straight link until then... I only have to drive a short ways
Did This Forum Post Help You?
