6.7 Harmonic Damper on a 5.9
AH64ID
Part of my rebuild is a fully balanced rotating assembly, and unfortunately the 6.7 dampers are not perfectly balanced. Of the 2 we tries 1 was 16 grams out of balance and the other 30, mine was the 16. There is also no way to balance them. It it sucks to pull because it has worked so well, but a fluidamper is going on. I can't justify a balanced crank, etc, and then not the damper. So while it sucks I will be able to review them both, thou not apples to apples with a balanced motor and new injectors.
The Fluid Damper I had on my 02 did awesome things on that engine, It smoothed out the lope considerably from having an HRVP44 combined with 155 hp BD injectors and Hot comp combined with a Smarty for a short time but the smarty wasn't compatible with the HRvp44 for a daily driver, One couldn't hardly drive it, throttle response was so super sensitive and jumpy even on smarty lowest settings.
