What part is this in the HVAC Box
It appears to be the resitor for you blower motor. You need to replace it if it has a piece broken off. You will loose the speeds on the blower motor. It is easiert to replace now than later. I dont think they are that expensive and much easier to replace while that dash is out.
if your resistor continues to blow you need to change the fan motor as it is gummed up and drawing too many amps burning out the resistor pack. I had this happen to my rig, it finally blew the original resistor block, so i purchased a new one. Well a month later it blew again and the guys at advance told me i need a new fan motor (it didnt dawn on me until then)you will know its blown as it will only run on high and nothing else. if im not mistakenReplaced the fan motor and all is well.
