STILL battling fuel gremlins
it is not a continuos pattern.basically when i first fire the truck after it has sat for a day, it will start, run fine for 5 seconds, then go to the chug which sounds like a miss, and then after that itll smooth out and run fine.in the video it lasted about 8 seconds, you can see the tach drop and the camera shaking a little. then it smoothed out and starterd purring like a kitten.THIS just struck me. in the time ive had this truck ive bled the fuel system at least 12 times. i do this through the bleeder bolt on top of the fuel filter, and pumping the LP primer. could my air leak possibly be the copper washer under the bleeder bolt?
Sorry I must correct myself.i dont have to prime it every time i start it. i primed it that many times because ive been doing alot of fuel system work and prime it every time i pop a hose off or take the fuel filter off etc.the question is, because ive bled it so much, could the copper washer under the bleeder bolt be the issue?
Well technically the bolt will be pressurized after the engine is running so as long as the bolt is not leaking while the engine is running I'm going to have to say no. But now all the fuel lines rearward of the lift pump would be suction lines and can leak without warning. Because the air will leak into the line draining it back to the tank.
Well my NASA thing requires some fancy fittings. The 2nd fuel port is M18 x 1.5 and going from that to a hose barb or something isn't something that any local stores sell. I would look all over it on the return lines and other stuff for any sign of fuel leaking since that would also be a spot for air to leak in. Air being thinner than fuel it might be hard to pinpoint, hence my NASA thing. I worked on a truck that had biodiesel hooked up to it which made him cut all the steel fuel lines and run rubber hose. He had an air leak and I replaced the rubber hose with clear rubber hose and mann was it easy to find. I would almost cut all my steel lines if it wasn't for the fact that steel lines are obviously very stout and will only leak at the fittings.
I need to jump in here, I just looked at this thread for the first time. You need to get that fuel out of the tank and clean everything out good.The black stuff in the fuel filter and screen is Fuel Algae which you should have caught on to in one picture you actually posted.You got a bad load of fuel somewhere and or got a load of water with some fuel which promotes the algae growth.You need to run a couple bottles of bio kleen or similar product through it to kill it.You will just keep the process going unless you get the system cleaned out. There is one other thing that can cause that black residue in the filter but that is found on HEUI "Hydraulic electronic unit injector" engines where the fuel is under extreme pressure and heat and returns to the tank for cooling I can't remember the term for this right now but it is a break down in the fuel from heat similar to having soot in your oil.
DANG so i gotta take my module out and clean my whole tank? it has about a 1/4 in it now, would it work to put it back together and run the fuel thats in the tank, then fill it back up and and run bio kleen in the next tank?? i thought algae came from sitting over time thats why it didnt raise a red flag to me.
Algae usually originates in bulk tanks that have moisture in them from condensation not necessarily from your own tank. It looks like oil because its waste is essentially a black slime imagine it as a type of slimey mold or pond algae it is microscopic but it just coats the filter like what you see in the pictures.You could run the tank empty and then fill up at a known good station and add an anti algae formula of some sort there are many brands get what you can get locally, most truck shops or truck stops should carry it.Any type of diesel is prone to algae but it is becoming more prevelant with the new Bio diesel blends.Us long term diesel techs like to refer to this as diesel Barnacles :lmao:You can do a search on diesel fuel algae and find tons of info on it.
I've had to deal with this over the years. It looks like black snot and can take time to get rid of it all. Once you start killing this stuff with the additives it will break loose from the sides of the tank or lines and follow the fuel flow. You will want to keep a few extra filters on hand because they will plug up quickly.
From Wikipedia:
[h=4]Algae, microbes, and water contamination[/h] There has been much discussion and misunderstanding of algae in diesel fuel.[25][dead link] Algae need light to live and grow. As there is no sunlight in a closed fuel tank, no algae can survive, but some microbes can survive and feed on the diesel fuel.
These microbes form a colony that lives at the interface of fuel and water. They grow quite fast in warmer temperatures. They can even grow in cold weather when fuel tank heaters are installed. Parts of the colony can break off and clog the fuel lines and fuel filters.
How can you tell between algae and just contaminants on the fuel filter? My fuel filter looks the same as his but I don't get oil on my hands when I touch it and it's not slimy. Mine is more like just a fuel filter that someone colored black, the media feels the same as new.
Thanks for adding some facts to the discussion bh. ISX the microbs or algae scrape off and feels like oily slime and plugs the filters up fast. as the info db posted above. It takes time to get it worked out of a system. The blackness you describe in you filter is totally normal as the fuel has additives and dirt and other things in it that will turn a filter dark over time. but the barnicles are thick slime and like to congregate.
WHEW thats a sigh of releif, taking the module back out and all wasnt sounding fun. so i guess the truck will be idleing in my driveway for a while once its back together :lol:. i will be making a stop at my local NAPA today on the way home to see what i can find.i cant thank the people that have chimed in enough. you guys really are top notch cummins owners :thumbup2:
WHEW thats a sigh of releif, taking the module back out and all wasnt sounding fun. so i guess the truck will be idleing in my driveway for a while once its back together :lol:. i will be making a stop at my local NAPA today on the way home to see what i can find. i cant thank the people that have chimed in enough. you guys really are top notch cummins owners :thumbup2:
You can change the filter 12 times or you can drop the tank and clean it out. I myself would clean the tank. The constant worrying about when the filter plugs and where you will be left sitting isn't worth the hassle in my book.:2cents:
i have the bed off so all would have to do is pull the module and suck the fuel out. if i go this route what would your suggestion be for solution to clean the tank with?? also can i burn the fuel i pump out of the tank? or should i fill with good fuel and disregard the contaminated fuel. at $4.23 a gallon its like gold anymore.
I would settle out the fuel and pump out the top 90% of it out of a 5 gallon buckets. But remember if it is algae problems the fuel is technically contaminated. But I agree with Wild and Free its best to clean the tank really good and start over. While your at it I would blow solvent through the fuel lines too... Make sure there is no other gunk floating around. Then monitor the filter housing... Sample some of the fuel in a clear bottle or such and see if anything shows up.
will simple green or some kind of cleaner work to wipe the inside of the tank down with?? And what exactly can i do with the diesel once its out. thinking that its contaminated the only thing i can think to do is dispose of it and start fresh. would it be possibly to mix it with fresh fuel later or should i just follow my gut and get rid of it?? Also what kind of solvent should i use to flush my lines??and heres the plan I've devised for this weekend-1) re install my lift pump and clean pre filter assembly.2) pull the module and pump the fuel out into a 5 gallon container.3) use whatever the recommended cleaner is and wipe down the inside of the tank.4) dump 5 or 10 gallons of fuel back in the tank and whatever additive i end up with and re install the module5) hook the lines back up and fire it
