- Replies 5
- Views 3.6k
98whitelightnin 2 posts
Mopar1973Man 1 post
AH64ID 1 post
Perrysburg Dodgeboy 1 post
Well it looks like I'm going to pull my injectors and send them to Superior Turbo and Injector in Detroit. They are going to test the injectors, clean, calibrate the coils, replace the brass cap and o-ring for $165. If it turns out that any fall outside of the specs or can't be brought back into spec they will replace them with their in house (Bosch certified) rebuilt injectors for $265 each. If I want Bosch factory rebuilt injectors they are $332 each.I was told that it is a good idea to replace the fuel tubes at the same time @ a cost of $35 each. What do you guys think about replacing the tubes? At 35 dollars it's not a big expense, but if they don't need to be replaced then why do it right?Don
