Auto trans build upcoming... Opinions & experience wanted
- Replies 16
- Views 3.6k
JOHNFAK 6 posts
CSM 4 posts
cajflynn 2 posts
Baconbitsforu 2 posts
The new truck I bought (2002 in sig) turns out to have a bit different trans than the seller advertised... I still would have bought the truck, but I need to make some changes. The trans was the only non stock part I couldn't verify before the quick sale the guy needed.The trans was supposed to be a BD torque converter, billet input, street/towing valve body, and sun coast guts. I did some hunting and found the shop that did the trans. The builder was a good guy and honest with me. He also let me know that his 3 year 36k mi warranty also applied to me, since he knows the truck. What I got was a hardened cryo treated input shaft, CVC stock replacement converter, good set of clutches/bands, and a mild hand modified valve body. I discussed the options with him in making the trans a bit more sturdy so I don't burn out anything prematurely. He offered a CVC single clutch billet converter that CVC rated at 1200 ft/lbs and a moderately worked street / strip valvebody for $600, and since he did the trans, he said he would keep the stock CVC converter for a $120 core, totaling $480. I am seeing a peak of 48 or so psi of boost when I roll on the throttle, and I want something that I could still tow some with, but something that will still run through the gears fairly well without burning out at either. I am thinking of taking him up on the deal, as the hardened input should be good for what I need and if the rest of the internals are okay I should be in good shape to drive and occasionally tow.As I've mentioned... I know little about automatics. What do you guys think?
