I have a miss as far as I can determine it is #6 cyl. I have eliminated the injection pump (VP44) because I can open all the fuel lines(short of #2,because of the intake) that make a difference in the RPM's (other words 2 cyls missing)except for #6 which has fuel being delivered,thus I have eliminated the VP44,I guess I need too make sure the valve's are opening correctly(which I thought I already did,but need double check)I have had the Injectors cleaned and set for proper pop pressure here at Diesel Specialties,No codes, so I know that I need to pull the head(not what I want to do) unless someone has another suggestion. :shrug:
My old motor would set a idle all day and sound just fine, drive it 300 yards down the road and it would start a slite miss. It had to do with heat as soon as the Egt's went up that would open up a crack in block,pistons or rings. New head did nothing.I do have a well stocked parts supply though. :lmao2:
