Oil sample back from Blackstone
Everything was great, with the exception of a mention of a small amount of soot in the sample. Used Mopar oil filter, changed to Baldwin. Just wonder what they mean about the soot in the sample.UpdateI know there is always soot present in the oil on a diesel, hince the coal black color of the oil. So......? Heres the report, what say you?[ATTACH]4282[/ATTACH]
3462_001.pdf
Soot it exactly what you think it is!!! It's the stuff that coats the inside of your tailpipe.:smart: And some of the stuff is gonna get past your pistons rings no matter.IIRC, that's the "insolubles" part of your analysis!! Based on this analysis, keep on driving like you are............ain't no problems with this analysis at all!!!:2cents:Do you run a "bypass oil filter"?????:shrug:
