going from 03 turbo to an 04.5-7 turbo??????????
al_fol
The downpipe will bolt up, and you can buy a plug from places like ATS, or just leave the solenoid installed and unplugged. They allow air thru when not powered. You will need to adjust the WG, as they open about 22-24 psig. The turbine is the same as your HE341, but the compressor is bigger (and about as big as you can go without severely unbalanced flow).
