Have not been around for awhile been working out of town. Now that I'm back home I want to upgrade the fuel filter system. Here is my ideal. I would like to remove the stock fuel canister and replace with the Fleetguard fs19596 with water in fuel sensor and Cat 1R-0750 after the raptor pump(frrp). After looking at the filter heads and the space where the canister is I think I can fit it all in there. What do you guys think? Will the raptor be able to handle the filters after it? Thanks
It should handle it no problem. I run 3 filters on my stock in-tank pump. Look into the Donaldson P551313, it's a slightly better filter for the same application.
