98.5 cranks but no start
my truck is not starting ?!!!!! when i go to start it, it just cranks and cranks im not getting any power to my lift and inj. pump. truck is stock but a couple people told me it was a bad ecm ? went threw the wires they seemed fine noticed im not getting rpms though when its cranking. so i replaced the crank sensor. still not moving. i got the lift pump to run with the relay jumped but plug it back in and it dosent fire up need some help maybe a wire diagram ??or just some expert thoughts !thanks !
I understand the engine turns over. Have you checked all the "other" wires connected to the batteries? I had my lift pump cut out, was traced to a connection a few inches from the passenger's side battery. Check the grounds too.
Ill check again were is the comm fuse ? O yeah and my wts light doesn't turn on at all
