oil in turbo
Could be seals are weeping. Maybe you have a worn shaft which could allow the seals to weep. If you are getting very much oil it will likely begin to coat your intercooler which will interfere with its ability to cool your charge air very efficiently.
not a lot of oil just a nice film. going outside and try to up load some pics thanks for the reply
that makes sense. I was just curious if burning oil like from bad seals like that would make the exhaust temp go up. If the oil is going into the intake, wouldnt that be bad for the intercooler? Could the oil build up enough inside of it to plug it maybe?
Oil in intercooler obviousy isnt good - but issue is like mike said - runaway engine. You need to pull the intercooler boot off and inspect the tubing to ensure all ok - shouldnt be any oil.
