What's the thread size on the vp & oem filter housing?
If you have the newer fuel canister, the one the filter loads from the top, both the inlets to the canister and the vp are the same thread size. That would lead me to believe to outlet on the canister is the same also. The banjo bolts appeared the same when I swapped mine.As far as the size, I dont know.
Was out in the garage a little bit ago and dug out my old banjo bolts and dripley is right they are the same size on the canister and vp. Double checked em with my tap n die set and they are 12 mm. I was thinking they were npt on the canister because my smaller ports where i draw my fuel pressure from is 1/8 npt. Also, this is on my 1998.5 im not sure about the newer style canisters bieng the same.
