- Replies 11
- Views 2.7k
AH64ID 4 posts
Mopar1973Man 3 posts
Wild and Free 2 posts
diesel4life 2 posts
Well I'm now really going for the gold now. I've managed to reduce from 5x5 to 5x3 on the Edge Comp and keep 20 MPG now. Certainly different driving style is required.
Now for those that are not owners of Edge products let me throw this out. Edge Comp and Edge Juice are both have the same in software basically. They both have 5 main levels and 5 sublevels.
MAIN LEVELS
[*]40 HP
[*]60 HP
[*]80 HP
[*]100 HP
[*]120 HP
SUBLEVELS
[*]33% of stock fueling/timing till 20 PSI of boost
[*]50% of stock fueling/timing till 15 PSI of boost
[*]67% of stock fueling/timing till 10 PSI of boost
[*]Some Extra fuel at 0 PSI of boost
[*]Full fuel and Timing at 0 PSI of boost
Now you got to remember I got winter time temps, my oversize tires 265's, and the tune of 5x3. Now I've changed over to the 5x3 and continued driving like I did previously and saw the MPG drop to nearly 16-18 MPG range. I relized that the timing curve was not available with low boos that I normal see of 1.5 to 3 PSI which is well below 10 PSI limit of the defuel mode of the Edge. So today figure I change driving style a bit and see if I could gain it back. Since my trip to McCall, ID is all up hill from home to McCall, ID all I did was left it 4th gear (NV4500) and set the cruise for 55 MPh as usual. This put my tach upwards of 2,100 RPM's and boost about 7-9 PSI the whole way up. Seems to gain slightly on the way up by the time I hit McCall, ID I had just barely touched on 15.9-16.0 MPG on the ScanGauge II. So now light foot around town and scratch up a few more tenths of MPG. Then on my way home I used 5th gear let the truck just roll down hill basically. By the time I hit the yard I was at 20.5 MPG. This is still experimental stag and I'm going to continue learning and testing to see if I can get the most of this tune.
More to come...
PS: Oh... I forgot to mention that with this tune I've got way more torque now and been having trouble even with my 265's tires. In 2nd and 3rd gears I just got to plant the pedal to the floor and the turbo lights and so do the tires.
